configure stpd multicast send-query
configure stpd multicast send-query [on | off]
Description
Configures suppressing IGMP- and MLD-triggered queries when STP topology changes are received.
Syntax Description
multicast Specifies multicast options.
send-query For VLANs associated with STPD, when topology changes occur, send or suppress IGMP or MLD queries.
on Send IGMP or MLD queries (default).
off Do not send IGMP or MLD queries.
Default
Sending IGMP or MLD queries is on.
Usage Guidelines
Whenever STP topology changes are received on a port, the switch sends triggered queries that mark the peer port as a router port and floods all multicast packets towards this port. This can cause unnecessary bandwidth usage. This command allows you to allow or suppress this forwarding.
The following example turns off IGMP and MLD queries:
# configure stpd multicast send-query off
This command was first available in ExtremeXOS 21.1.5-Patch1-2.
Platform Availability
